Fuel tank shut off - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 12 (permalink) Old 03-23-2008, 10:51 AM Thread Starter
Fuel tank shut off
Yes, I'm a "newbie"! I bought a used "Vulcan Drifter" from the dealer here in Springfield,Ill. Rode some last year. they told me I didn't have to shut the fuel off, so I didn't. I have ordered a "manual" from them. In the mean time, I can't get the bike to start, seems flooded all the time. (soaked plugs) so I looked at the valve on the tank, and it says "res", "pri", and "on". Took the fuel line off and watched - NONE of them seem to shut the fuel off. it drips out when on res. and on, and runs out like crazy when on pri. Is there an off?
Thanks,
Davo
Davo is offline
post #2 of 12 (permalink) Old 03-23-2008, 11:13 AM
hasbeen
Your fuel petcock should not run fuel when "on" or "reserve" and should only free flow when on "prime" or when there is vacuum applied to the petcock.
Be sure to address the root causes.
Problems
1. Your petcock is bad or stuck open, free flowing at all times
2. Your carbs are not stopping fuel flow via float/valve, overflowing flooding the engine, fouling the plugs.
My guess is you have some debris in your tank causing all these issues and a shut off valve may provide an instant improvement it may not be a permanent solution. If the carbs are flowing enough gas you may have it in your oil too. Check your oil level and do the sniff test.
indianaroadracer is offline
post #3 of 12 (permalink) Old 03-23-2008, 05:19 PM Thread Starter
Thanks!
I'm off to the garage! My wife's aready complainin' about the " fuel smell"? Ha! Been a mechanic all my life, ya'd think she'd be used to it!!
Davo
Davo is offline
post #4 of 12 (permalink) Old 03-23-2008, 08:03 PM Thread Starter
Ok,
Drained the tank, pulled the fuel petcock, looks like there is no "off" by the knob.
Found some little "white stringy" things in the valve. Seen them before in carbs - seem like since the introduction of alcohol in gasoline. Have to flush the tank yet, then replace the valve. My question is - when in run or reserve, can the valve allow any fuel? like drip? or not? I'm guessing not, but wonder.
Thanks,
Davo ps, can't wait for my manual!!!
Davo is offline
post #5 of 12 (permalink) Old 03-23-2008, 08:31 PM
hasbeen
Originally Posted by Davo View Post
Ok,
Thanks,
You fuel petcock has two hoses connected to it, yes???
One is the fuel line to the carb/FI body (is your bike FI?)
Second is a vacuum line connected to the intake manifold
In normal operation, the vacuum petcock valve is held closed by the small spring. When the bike is running the vacuum pulls the valve open and allows fuel flow. In prime, the fuel flows around the valve. Typically a vacuum petcock will not allow fuel to seep or drip.
If you found debris in the petcock I would throw it back together and try it as new petcocks are EXPENSIVE. You can test it on your bench to see if it seals and by applying a small amount of vacuum to the petcock to see if it opens when vacuum is applied. I would use a clear hose and suck on it to check the vacuum. Note, it doesn't take much vacuum at all and too much will also cause damage, ie don't connect a mighty vac and start pumping.
post #6 of 12 (permalink) Old 03-23-2008, 08:51 PM Thread Starter
Thanks!
I'll check it. Mine is not fuel injected, it has a carb.
Thanks again,
Davo
Davo is offline
post #7 of 12 (permalink) Old 03-24-2008, 04:21 PM Thread Starter
Indianaroadracer,
THANKS! I got 'er runnin' Did what you said. No fuel dripping from the fuel valve now!. I'll let her sit over night and check again! I think it's a winner!
Thanks again!
Davo
Davo is offline
post #8 of 12 (permalink) Old 03-24-2008, 06:29 PM
hasbeen
Indianaroadracer,
Thanks again!
Davo
Excellent, as I would guess that fuel petcock around $70.00.
post #9 of 12 (permalink) Old 03-26-2008, 09:17 PM Thread Starter
I'm "smiley"!
The bike has been starting every time. Thanks again!
Davo
Davo is offline
post #10 of 12 (permalink) Old 03-27-2008, 06:30 PM
hasbeen
No problem, you can repay me by posting some pics of your ride
