Back cylinder leaking/smoking - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 11 (permalink) Old 12-06-2012, 12:35 AM Thread Starter
Hey guys,
Looks like I've gotten my first big problem with the bike. Once the bike gets warmed up, I get some huge smoking (white) coming off the rear cylinder at take off out of the tail pipes. Doesn't happen while I'm scooting along, just at take off and idle. Wondering if anyone has any ideas/comments/concerns on this situation? Wanna get some ideas rolling around so I have a place to start when I tear it apart this winter (if it comes to that).
Thanks peeps!
Bike Info:
1997 Kawasaki Vulcan 1500A
Just hit 20,000 miles on the odom.
Mercness1112 is offline
post #2 of 11 (permalink) Old 12-06-2012, 02:55 AM
rick's Avatar
White smoke is water. If your lucky, is only head gasket. Would definetly tear it down ASAP!, no riding. If head is warped, your looking at many$$$. Just priced them for my 800 at $790 each.
2005 800 classic
2012 Voyager ABS
rick is offline
post #3 of 11 (permalink) Old 12-06-2012, 10:48 AM
White smoke can also mean excess fuel. That bike has dual carbs and I am thinking that the carb that feeds the rear cylinder has problems and leaking internally.
Both carbs should be torn down for a clean and inspection with replacement of any questionable parts. Pay particular attention paid to the needle and seat, and the float.
sfair is offline
post #4 of 11 (permalink) Old 12-06-2012, 11:02 PM Thread Starter
It wasn't till you guys said white smoke that I noticed I had put (White) and not (blue). It is for sure an oil leak somewhere. You can smell the oil and not antifreeze or anything like that.
post #5 of 11 (permalink) Old 12-06-2012, 11:22 PM
Comanche's Avatar
Time to pull the heads off first and slowly methodically work your way from gaskets, 0-Rings, valves, etc. and work your way down to the pistons, rings and jugs etc. Can't see what the problems are unless you crack her open.
Comanche is offline
post #6 of 11 (permalink) Old 12-07-2012, 12:08 AM
Excess fuel can cause blue smoke too.
What do the plugs look like?
Post back.
sfair is offline
post #7 of 11 (permalink) Old 12-08-2012, 08:18 AM
MickeyNew's Avatar
Do you use a Supertech oil filter?
2005 Nomad, navy and silver.
MickeyNew is offline
post #8 of 11 (permalink) Old 12-08-2012, 01:22 PM
Comanche's Avatar
Haha! Might as well ask if he has a bell on his bike while you're at it.
Comanche is offline
post #9 of 11 (permalink) Old 12-09-2012, 11:04 AM
Bear2123's Avatar
Bear2123 is offline
post #10 of 11 (permalink) Old 12-10-2012, 01:24 AM Thread Starter
I do indeed have a bell! May need to change the gremlin juice out soon, however. sfair-- I'll pull the plugs out tomorrow and post back.
