Microfiber warning - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 18 (permalink) Old 11-17-2012, 06:57 PM Thread Starter
Microfiber warning
Went to wipe down my bike after my ride this afternoon and the MF touched the hot exhaust pipe, just for maybe half a second. It instantly melted it on the pipe. Left a hard coating imprint of the towel that was extremely difficult to remove. Ended up scraping it off little by little with a sharp blade then cleaning it up with steel wool. Probably not an ideal solution as the blade left some fine scratches in the chrome.
Anybody else ever have this issue and how did you get it off?
2006 Vulcan 500 LTD
2013 Suzuki V-Strom 650 ABS Adventure
Gary W. is offline
post #2 of 18 (permalink) Old 11-17-2012, 07:12 PM
bosco's Avatar
My Sons bike had melted cover on the pipes. We were able to remove with heavy duty EZ off oven cleaner. Just heated the pipe up, sprayed on the ez off then wiped right off. Would never know it happened. You should be able to buff out the chrome once you get all the scratches down to a fine or satin looking finish.
2010 900 Classic
bosco is offline
post #3 of 18 (permalink) Old 11-17-2012, 07:13 PM
rick's Avatar
I've seen on here about using a Magic eraser to remove burnt on shoe soles. Should work for micro fiber clothes to.
rick is offline
post #4 of 18 (permalink) Old 11-17-2012, 08:23 PM
Soak a rag in Afta and let it sit for a while, then scrub with Magic Eraser. Takes while, but works well.
2008 VN900 Custom
crazyj is offline
post #5 of 18 (permalink) Old 11-17-2012, 08:56 PM Thread Starter
Thanks for the tips. Crazyj - what is Afta?
2006 Vulcan 500 LTD
Gary W. is offline
post #6 of 18 (permalink) Old 11-17-2012, 09:13 PM
Red Rider's Avatar
http://www.superkleendirect.com/afta.aspx
09 Vulcan 500 LTD
Red Rider is offline
post #7 of 18 (permalink) Old 11-18-2012, 01:17 AM
I've also heard that the EZ Oven cleaner works great after heating up pipes, just be careful not to get it on painted surfaces.
Taz_FL is offline
post #8 of 18 (permalink) Old 11-18-2012, 01:53 AM
Comanche's Avatar
That's why I don't use anything but those heavy duty cloth type drying towels that you buy at the car wash or a store and a good old fashioned high quality chamois. Good tips though in case I ever run across this with someone else.
Comanche is offline
post #9 of 18 (permalink) Old 11-18-2012, 06:19 AM
Thanks, Red Rider; where I am Afta, a great solvent for paints, plastics, adhesives, etc., is available at Home Depot. Great stuff, similar to Goof-Off.
2008 VN900 Custom
crazyj is offline
post #10 of 18 (permalink) Old 11-18-2012, 09:42 AM
This is probably off topic but Frog Toggs do the same disappearing act when only contacting the exhaust for a fraction of a second. I used a wet popsicle stick and some non abrasive comet soap powder and it eventually came off, The new Frog Toggs didn't fare so well however. I guess it's back to my Nelson Riggs.
'06 Vulcan900 Classic Candy Fire Red
Memphis Shades w/quik Disconnect
Cobra Sissy Bar and Rack
Lindby Multi bar with Kury Silver Bullets
Kawi Light Bar w/55watt bulbs
Kury PowerPoint
Kury Brake Light Kit
ISO-Grips W/Throttle Boss
VistaCruise Throttle lock
LeatherLyke Hard Bags
Pirelli MT66 W/Dynabeads
RoyVN900 is offline
