Won't start need help please! - Page 24 - Kawasaki Vulcan Forum : Vulcan Forums
post #231 of 299 (permalink) Old 01-06-2013, 12:49 PM Thread Starter
jhonathan978's Avatar
Originally Posted by 07vn2000 View Post
The "F" is for TDC front cylinder makes it easy to get bolts out of cam sprocket.
Doesn't need to be at "F" as long as you can get the cam out. Take the timing chain tensioner out first. Sometimes the is enough slack you can lift the end of the cam away from the sprocket and work the chain off the cam sprocket without removing the bolts.
Oh ok cool thanks I was wondering how I was going to get it out thought it had to be on "F"
jhonathan978 is offline
post #232 of 299 (permalink) Old 01-09-2013, 12:09 PM Thread Starter
Never mind got it off Ok I can't get this to come off any more its like stuck any ideas Click image for larger version
Name:	ImageUploadedByMO Free1357754958.724214.jpg
post #233 of 299 (permalink) Old 01-09-2013, 12:17 PM Thread Starter
This is the rear one doesn't look goodClick image for larger version
Name:	ImageUploadedByMO Free1357755433.149688.jpg
post #234 of 299 (permalink) Old 01-09-2013, 12:21 PM Thread Starter
And this is the front one looks like I should get a new engine. What do you guys think?Click image for larger version
Name:	ImageUploadedByMO Free1357755693.845280.jpg
post #235 of 299 (permalink) Old 01-09-2013, 01:24 PM
Does the engine turn over now with the wrench?
sfair is offline
post #236 of 299 (permalink) Old 01-09-2013, 01:26 PM Thread Starter
No still have that part from the crank case stuck in the case remember its bolted on
post #237 of 299 (permalink) Old 01-09-2013, 01:45 PM Thread Starter
This is as far as I got not sure if its worth moving forward or just buying new engine
Name:	ImageUploadedByMO Free1357760723.771235.jpg
post #238 of 299 (permalink) Old 01-09-2013, 05:19 PM
07vn2000's Avatar
It maybe time to start looking for a new engine.
What is the difference between the meanstreak and classic engine ? just cams and efi?
07vn2000 is offline
post #239 of 299 (permalink) Old 01-09-2013, 05:25 PM Thread Starter
So a classic engine would fit in my meanstreak
post #240 of 299 (permalink) Old 01-09-2013, 05:28 PM
Keep tearing it down and see if you can find the cause of your problem.
Do not right it off just yet.
It would be nice to plot the sequence of events...eg. maybe something like this:
1. Something on clutch came loose.
2. That item snagged crankcase bolt and broke the case.
3. Part of crankcase is wedged between ??? and ??? causing the crank not to turn.
sfair is offline
