Won't start need help please! - Page 2 - Kawasaki Vulcan Forum : Vulcan Forums
post #11 of 299 (permalink) Old 11-18-2012, 11:26 AM
MickeyNew's Avatar
I had a battery go out suddenly on my Nomad. I couldn't even jump it off with it in the bike. This will happen when two cells short together and drop the voltage.
2005 Nomad, navy and silver.
MickeyNew is offline
post #12 of 299 (permalink) Old 11-18-2012, 11:30 AM Thread Starter
jhonathan978's Avatar
I will charge my battery when I get home. I will let you know if it works thanks
jhonathan978 is offline
post #13 of 299 (permalink) Old 11-18-2012, 11:34 AM
MickeyNew's Avatar
My battery would not charge. As already suggested, take the battery to an auto parts store and they will test it for you for free.
post #14 of 299 (permalink) Old 11-23-2012, 08:56 PM Thread Starter
Just charge my battery 100% and it still does the same any other ideas
post #15 of 299 (permalink) Old 11-23-2012, 09:09 PM
Have you checked all the voltage readings on the starter circuit from the battery through the starter solenoid then to the starter itself?
Check the voltage at each end of the cables.
Sent from my GT-I9300 using Motorcycle.com Free App
My stepping stone to what I'm riding now.
Suzuki GSX250 '82
Suzuki GSX-R600 '00
Vulcan VN1600 Classic '06
Fitted: tachometer, genuine windshield, K Drive hard bags, upgraded Meanstreak clutch spring with Judges washers, Cobra Speedster Longshots, Dobeck TFI controller, Chucksters air filter plate, Mustang seats with drivers backrest.
Up coming items: volt meter, oil and temp gauges.
Busboy is offline
post #16 of 299 (permalink) Old 11-23-2012, 09:14 PM
smedlin's Avatar
you never did say if you took the battery and had it tested. You might have a cell that went bad.
Yes, I'm a Chrome Whore.
2004 Vulcan 2000
smedlin is offline
post #17 of 299 (permalink) Old 11-23-2012, 09:17 PM Thread Starter
It's a brand new battery and it charge up fine. I will check out the voltage tomorrow thanks
post #18 of 299 (permalink) Old 11-23-2012, 09:17 PM Thread Starter
Does anyone know if maybe the engine is seize up
post #19 of 299 (permalink) Old 11-23-2012, 09:38 PM
Take the spark plugs out then put it in gear and see if the bike still moves as the pistons will still be able to move up n down the cylinder.
Suzuki GSX250 '82
Suzuki GSX-R600 '00
Busboy is offline
post #20 of 299 (permalink) Old 11-23-2012, 09:42 PM Thread Starter
Ok I'll try that tomorrow when I get home. So if it in gear won't it not roll
