Leaking Oil - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 7 (permalink) Old 04-19-2012, 08:41 PM Thread Starter
Leaking Oil
I'm reposting this here 'cause it didn't get a response in the 1500 forum. I came out of a diner this morning and noticed my bike was dripping oil. There were 3 small puddles: one from a drip off the kickstand, one from behind the kickstand (frame), and a third from a drip off the rectifier cover. I checked my oil pan plug and oil filter, both dry. Also checked the garage floor when I got home and it was clean, so this leak started when I was at the restaurant.
Does this sound serious? Are gasket/seal issues a big deal? I have noticed lately a knocking that's louder than usual. Other than that, the bike's been fine. Thanks.
_____________
IntheWind
'06 1500 Classic
inthewind is offline
post #2 of 7 (permalink) Old 04-19-2012, 08:45 PM
Ol'Yella's Avatar
Did you recently do spark plugs, valve adjustment any maintanance at all? On the 9's there is a seal/o-ring on the bottom of the spark plug tube. If the seal gets crunched or not aligned properly oil runs otu the side of the cyl and down. Check all your crank case vent tubes as well. I didn't get a clamp quite seated enough and one popped off after I did plugs. It knocked and sounded real bad and was a 5 sec fix.
08' 900 Classic solar indy yellow
Ol'Yella is offline
post #3 of 7 (permalink) Old 04-19-2012, 11:30 PM Thread Starter
Had the bike serviced 3 weeks and 1,100 miles ago, but it was only a minor service--oil change, tire check, etc...
I've read elsewhere that the "clutch pushrod seal" on the 1500/1600s often fails between 40k and 50k miles. A symptom is oil running down and pooling around the kickstand. That's pretty much what mine's doing. I'm bringing it in tomorrow. I hope my back tire doesn't get slicked up on the way.
_____________
IntheWind
'06 1500 Classic
post #4 of 7 (permalink) Old 04-21-2012, 01:28 AM
Windburn Bill's Avatar
One question...is it dripping oil or hydraulic fluid?
If it is oil dripping off the back of the kickstand it probably is the clutch push rod seal. This is a common problem with the 1500/1600's. It's easy to replace, you can do it at home in 2 hours and the new seal costs about $9. There's a thread around here somewhere with the details. I'll see if i can find it and will post it.
If it's dripping hydraulic fluid it's probably the clutch servo piston gasket, again, a simple fix you can do at home.
'05 1600 Classic. Black...the fastest color.
Harley Street Glide 18" front wheel
Lowered Using Honda shocks
Barons PB's, Flanders bars
Cobra True Duals
Hypercharger
Dobeck TFI
Mutazu HL hardbags
One off drivers back rest
Windburn Bill is offline
post #5 of 7 (permalink) Old 04-21-2012, 07:39 AM
This might sound weird, but are you sure it was coming from your bike and not there when you parked it? Since it wasn't on your garage floor I'm just wondering if you actually saw the dripping from the bike or just on the ground?
'04 1500 Classic
WilburDink is offline
post #6 of 7 (permalink) Old 04-21-2012, 10:23 PM Thread Starter
Bill,
I brought it in yesterday. It was the clutch pushrod seal... My mechanic popped it back in and it's holding for now, but he said it won't hold for long so I ordered a new one. He's going to relocate the rectifier to under the radiator when he replaces the seal. I figured I'd "kill two birds with one stone" as they say.
_____________
IntheWind
'06 1500 Classic
post #7 of 7 (permalink) Old 04-21-2012, 10:26 PM Thread Starter
There's no mistaking this. You don't just see the puddles, you see the oil dripping. Fortunately I was only a mile from home.
______________
IntheWind
'06 1500 Classic
