I finally got in a ride today after several months of PT for my arthritis and bones spurs in my shoulders. I didn't ride long (maybe an hour) because I didn't want to over do it the first time out. However, even that short time let me know that I could benefit from a couple of inches of pullback on the bars, especially for long distance riding. The height is perfect with stock risers and bars.
Sitting more forward is not an option. I did that on a trip last summer with my luggage on the passenger pillion pushing me forward a bit. Not a comfortable position for me.
My question: Anyone know of any risers for the Voyager that add 2" of pullback, but no more rise than stock? Alternately, bars with 2" more pullback, but no wider would work.
I had the same problem, but due to the fact that I'm short. I went from the stock 1.5" riser to the 3.5" it brought it back just enough. And you will be able to adjust the height of the bars where you need them.
I installed risers that are two inches up and two back and what a difference it made. Really made a difference on my back and even on my wrists and arms.
Thanks guys. Yeah, most risers won't work as I described, but I was hoping someone knew of some brand that would. Graybush's suggestion is just the kind of thing I was looking for (and the prices are not bad, either).
The main reason I didn't want to have to adjust the bars down on higher risers is the steeper angle on the grips makes controlling the throttle more difficult on slow, tight maneuvers. I can deal with it if I have to, but would rather not.
What I did was bought risers that raise the bars1-3/4" and back 2". You can loosen the bar set screws on the risers and experiment with tilting the grips up or down until they feel right, then tighten the bars down. Two inches up won't change the angle of the grips hardly at all.
Related Threads
Kawasaki Vulcan Forum
712.7K posts
67.8K members
Since 2008
