melted plastic on muffler - Page 2 - Kawasaki Vulcan Forum : Vulcan Forums
post #11 of 24 (permalink) Old 12-06-2012, 01:42 PM
Bear2123's Avatar
Easy Off oven cleaner. Put it on a warm to hot pipe, leave it overnight, or at least a few ours, and just wipe it off. Nothing is easier than that.
Bear2123 is offline
post #12 of 24 (permalink) Old 12-06-2012, 02:32 PM
R-man's Avatar
I have a can of automotive paint thinner that works great. Probably similar to acetone.
2004 Vulcan Classic 1500 - carbed
Grips, Freeway pegs, engine guard
Floorboards, Nomad rear seat,
Custom made luggage rack, Windshield & Lowers
Saddlebags, Passenger floorboards,
Passenger armrests
R-man is offline
post #13 of 24 (permalink) Old 12-19-2012, 03:01 PM
red_leg's Avatar
Originally Posted by Old Bear View Post
I used 000 steel wool and WD-40, cleaned up slick and easy!
The 000 steel wool works great. I had a bit of plastic melted on, maybe 1 in square, much smaller than what you've got, but the steel wool and a little elbow grease worked great to get it off.
But use 000 steel wool, can't stress that enough
red_leg is offline
post #14 of 24 (permalink) Old 12-25-2012, 12:48 AM
Take 4 fingers of Jack Daniels and add 4 ice cubes. Take one of those cubes and rub it over the plastic to chill it then a razor blade under the plastic and it should come off. Then drink the JD. Once off give the pipes a good polish.
Cheers and Beers.
Bob
Popeye is offline
post #15 of 24 (permalink) Old 12-25-2012, 05:59 AM
Vandy's Avatar
I was just told the other day that Soft Scrub and a Mr Clean Magic Eraser work absolutely flawlessly...
But I was treated mercifully because I didn’t know what I was doing—didn’t know Who I was doing it against! Grace mixed with faith and love poured over me and into me. And all because of Jesus. Here’s a word you can take to heart and depend on: Jesus Christ came into the world to save sinners. I’m proof—Public Sinner Number One—of someone who could never have made it apart from sheer mercy.
1Tim 1, MESS Bible
2006 Vulcan900 Classic
Vandy is offline
post #16 of 24 (permalink) Old 12-28-2012, 12:21 PM
Originally Posted by fysl View Post
A plastic bag got stuck on the muffler while it was hot and melted on it , I tried to clean it off but it's stuck on it so hard , what to do ?
I had the same problem, Easy Off oven cleaner solved it. Warm.up the engine first
2011 Vulcan Voyager 1700 CSC Kruze Trike
Kuryakyn black ISO grips
GPS holder // Garmin C580
RAM cup holder // Trunk Rack
Scala Rider G9 ProSet
Señor Pete is offline
post #17 of 24 (permalink) Old 12-28-2012, 04:14 PM
Murphy's Avatar
I tried the oven cleaner and it did not work for me.
Next time I will try some of these other remedies
000steel wool and wd40 sounds good.
06 VN1500 Classic Anniversary
Murphy is offline
post #18 of 24 (permalink) Old 12-29-2012, 12:11 AM
bosco's Avatar
Used extra strength easy-off. Heated the pipes sprayed on cleaner and let sit (as described in the instructions). Wiped right off.
2010 900 Classic
bosco is offline
post #19 of 24 (permalink) Old 12-29-2012, 06:57 PM
ChevelleSSLS6's Avatar
Originally Posted by OverHillAndDale View Post
I got mine off without damaging the chrome using a dremel with a small wire-wheel. I was suprised that it took off the plastic without leaving any scratches. The wire wheel had approx 1/4 inch fibers that were fairly stiff.
brass wire wheels are the softest. I'd start there (or some high tech plastic wheel) before going to traditional steel or stainless.
2007 Ninja 650R traded in and missed
2009 Vulcan 900 Classic current Kawi
900cc=55 cubic inches
Is there a Gadget page for us 900 owners???
Vulcan 900 "oily air filter" fix
Get 3-4 feet of tranny line from parts store that's the same ID as the stock vent line. Attach to jug, route hose up to bottom of fuel tank around wires and back down to airbox, cut off excess (leave a little slack so wires are NOT under tension) and attach to airbox. Reinstall everything.
ChevelleSSLS6 is offline
post #20 of 24 (permalink) Old 12-31-2012, 12:35 PM
I put my chain lock over the muffler too soon and the sleeve melted on a little.
Just cranked it back up and let it get hot and then cleaned it with a very damp clean cloth.
evocraig is offline
