Vulcan 500 seat removal - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 15 (permalink) Old 05-06-2009, 10:10 AM Thread Starter
When I tried to start my Vulcan after the winter, the battery voltage was down, and I got a 'no start'. I put a charger on it, but the voltage dropped, which to me means, I need to put water in the battery, or get a new one.
Of course, I need the seat up to get at the battery, etc. The seat key would not release the seat, so I freed up and pulled on the cable, but still the seat won't release.
I pulled on the cable only. Does the outer cable shield need to be pushed against, is it a double action that is necessary?
Any suggestions? I know I will have to replace the cable, keylock, etc., but is there anything else I can do?
Can I dig out the battery overflow plastic tube, and fill the battery from there?
Thanks for any help you can give me.
billzbiz is offline
post #2 of 15 (permalink) Old 05-06-2009, 10:16 AM
silversurfer's Avatar
did you remove the screw at the back of the seat?
2007 1600 Classic
Vance&Hines Bigshots
Lindby Multibar
USMC 85-91
silversurfer is offline
post #3 of 15 (permalink) Old 05-06-2009, 10:32 AM Thread Starter
Screw at the seat back?
I didn't have to remove any screws before when I removed the seat, just turn the key. Unfortunately, I was too strong in turning the key when it would not open, and bent the key at the shank. Now I have removed the key lock to expose the cable, and can pull on the cable directly.
So, the seat front fits into a moveable clamp, and the clamp won't release. At least that's what I think is happning.
Question, if there were a screw at the back of the seat that needed to be removed, how would I access the tool kit (which is under the seat) to get a screwdriver?
billzbiz is offline
post #4 of 15 (permalink) Old 05-06-2009, 10:37 AM
what year do you have? My 07 had a screw at the back of the seat. The tool kit was in a side mounted compartment.
2007 1600 Classic
Lindby Multibar
USMC 85-91
post #5 of 15 (permalink) Old 05-06-2009, 10:41 AM Thread Starter
Year
It;s a 1995, Vulcan 500.
billzbiz is offline
post #6 of 15 (permalink) Old 05-06-2009, 10:42 AM
Did you try looking in the MoM to see how it comes off?
2007 1600 Classic
Lindby Multibar
USMC 85-91
post #7 of 15 (permalink) Old 05-06-2009, 10:51 AM Thread Starter
MoM? Motorcycle Owners Manual?
billzbiz is offline
post #8 of 15 (permalink) Old 05-06-2009, 10:53 AM
Yep, sorry
2007 1600 Classic
Lindby Multibar
USMC 85-91
post #9 of 15 (permalink) Old 05-06-2009, 11:01 AM Thread Starter
I'll take another look tonight. As it is, I pulled on that cable pretty hard, and even used a pry bar for leverage, but still couldn't budge it. I wondered if there is a trick to it, like pull the inner cable and hold the outer sheath, or is I can get underneath and unscrew something. I used to be handy with tools, but have pushed a keyboard for too long to keep my skills. Guess I will have to relearn!
Thanks for your efforts.
billzbiz is offline
post #10 of 15 (permalink) Old 05-06-2009, 11:04 AM
hopefully someone will get you pointed in the right direction if you don't figure it out. Good luck
2007 1600 Classic
Lindby Multibar
USMC 85-91
